What I would have gone with personally - unless your into high end overclocking or want lots of connections the P43 is a simple, stable and fast board and I'm not a fan of Asus myself
While corsairs value RAM has been fantastic - I've not had a great run with corsair XMS kits personally so would avoid those as well myself.
Play CSS myself. In a one night competition tonight on ED.
Anyways my spec (sig) gets me easily 150+fps on pretty much all maps.
imo i would look at a high clocked dual core if you want it for CSS (E8x00)
If your just using it for gaming, you would probably be better off getting a dual such as the E8400 then the Q6600, due to higher clockspeed duals being better for most games and it should be cheaper as well.
