- 11 Aug 2012
- West Sussex
Hi everyone. I built my PC sourced fully from overclockers back in like 2013 . No problems since.
Heres the specs.
i7-3770K @ 3.8GHz (Ivybridge) - Alpenfohn K2 - Gigabyte Z77X-UP4 - 16Gb DDR3 - GTX 670 - 2x 128Gb Samsung SSD - 1Tb HDD - Corsair HX 850W ATX - NZXT Switch 810 Big Tower Case - White
My issue is. It's recently started to not post and all sorts. And the only issue from years ago is that it stopped letting me access bios. But that was never a problem. So I took to too of man and he's just called me and said it's mobo failure. Now I'm all about not blowing money.
So I need a new mobo. Then I thought. I could buy the same one again? 60£ it seems.
My only question is. Is it possible for me to do that? Take out the current CPU? Slot it in the new mobo? Take off the old thermal paste? Apply new paste? Is that how it works? I presume the old paste won't come off? Can I apply ontop?
Or..... Is it the case.... That I need a new CPU as well? Hopefully not. I'm confident that the first options are doable.
I'm not too bothered about the future as I ll just run the mobo till it fails or something else fails I'm not that bothered about buying to keep up with gens and all that.
Hope you all can help. Thanks
Heres the specs.
I kind of want to get started sooner rather than later. So might start searching for an on sale mobo that fits the cases and suits my current components if I start getting desperate.
I ll pick my pc up Tuesday evening .
