- 1 Feb 2021
I am trying to buy a gaming PC for my son to play fortnite on, he wants 200+FPS and I only have £1000 to spend. I am completely overwhelmed with the technical info so looking for some help please.
Well £1000 should just about cover the gpu then . Not a good time to be building a new pc. You could re mortgage though??
Thank you so much that is really helpful.The problem right now is Graphics Cards (GPUs) are incredibly scarce to find, as the new models have launched in the last 4-5 months. Even older models are non-existent stock everywhere you look, and if they are in stock they're stupidly over-priced. The same situation is happening with the new PS5 and Xbox models...
The pre-built PCs on OcUK aren't that great on particular parts imo. If you need it pre-built, my suggestion would be to post in OcUK's customer service forum here - give them something like the below custom part list... and ask what "build stock" gpus they have available if any!?
at the same time ask how much they'd charge total to build this system up for you with the graphics card. something like a nvidia 1660 super, 2060 or amd 5600 xt could be possible... (i noticed they have msi 1660s in build stock on their configurator)
the below would be a great system (with a decent gpu added). not sure why he wants "200 fps" sounds like he's heard his friends talk big numbers, it's not needed lol. a 1660 super would give him 100+ avg fps (@ 1080p) which is more than enough. but if you can somehow manage one of the new models like a 3060 ti then you'd be laughing for £370.
edit: you would need to buy windows 10 which can be had for £5-10 if you look online at auction sites etc.
my basket at overclockers uk:
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £188.99
- 1 x Kingston HyperX Fury RGB 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz Dual Channel Kit= £79.99
- 1 x WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T2B0C)= £94.99
- 1 x Corsair RM Series RM650 650W '80 Plus Gold' Modular Power Supply (CP-9020194-UK)= £87.95
- 1 x Phanteks Eclipse P360 Air Mid Tower Case Tempered Glass DRGB - Satin Black= £68.95
- 1 x MSI B550M PRO-VDH WiFi (AMD AM4) B550 Micro-ATX Motherboard= £129.95
personally id get an ATX full size not a mini one
