Hey!
I still cant stop it from freezing/sound buzzing
please can you help, heres what i have done up to now;
Re-installed ASUS AI suite (its not a very stable program, though it could be the issue)---no change (tried without it instaled also)
Re-installed flash player (i can replicate the problem best when using 4od, though it does happen when just opening a program)
Re-installed the sound driver (no change)
Unplugged and re plugged everything inside, and out (no change)
Removed the GPU and run on IGFX (no change)
Installed the latest BIOS from asus website (fresh bios settings) (no change)
Run OCCT linpak and Prime95 (does not replicate the problem, but the mouse response does stutter with prime 95)
None of the above have made any difference. the voltages shown for 3.3v 5v and 12v in asus ai suite are 3.92v 5.08v 12.288v respectively and they barely fluctuate even during cpu/gpu stress testing (msi kombustor).
ive re enabled the XMP profile, and left it to do what it wants (1600mhz and 1.65v RAM and its timings) but this has no effect either, the problem still persists
has anyone got any ideas, could this be a PSU prblem?
