PC Problem!
29 Nov 2008
A few days ago i was on my PC playing BioShock, and the monitor randomly went off, still had power, and my PC was still on, and running but i had to restart PC.
It hasnt happened for about 5 days, but its happened again when i was playing CS:S i was playing and the screen went off, but the PC was running fine, whats going on? Is it the amount of power my PC needs because i only have a 450W PSU? HELP!
Did your try Alt-Tab or Ctrl-Alt-Del just to be sure the game hadn't crashed?
450W should be enough for that spec but what's the ratings especially +12V Rail?
Try monitoring temps also.
EDIT: GPU-Z or HWMonitor or SpeedFan (for CPU, chipset, HDD but not GFX)
What make/model is the PSU? Use CoreTemp for the CPU temps and RivaTuner for the graphics card temps.
