PC problem
11 Feb 2010
Don,t know how to explain this but I'll try. Just turned my pc on took longer then normal to launch to windows xp. when it did my desktop came up with all my programmes( which i cant move around) on it but the tool bar has gone it says that i have no connection yet the light are green saying i do. cant load up internet explorer. I have a application errror for skype saying exception EOlesysError in module skype.exe at 0002EAC1. the RPC server is Unavaliable. any help guys?
Sounds like the system has hung whilst booting and from the error message it seems that skype might be the culprit. If a couple of reboots doesn't help hit f8 whilst it boots and go in to safe mode. Maybe then remove skype using add remove programs, reboot and see what happens.
Best,
E-I
when trying to remove skype it says ' the windows installer service could not be accessed. this can occur if you are running windows in safe mode, or if the windows installer is nor correctly installed. cantact your support personnel assistance.' really dont know what to do
okay,
Plan b. when in safe mode type msconfig into the run area.
Then select the startup tab and look for skype in that list. If its there deselect it, reboot and see what happens now. Hopefully that will stop skype starting up, so might mean you can get back into windows normally.
I googled your problem a little earlier and found someone with similar issues who some how was missing svchost.exe (which as far as I understand is used by several bits of software) so might be worth checking if you can see that in your process list.
Best,
E-I
From the windows button in the bottom left, there's an option to 'Run' select that and enter msconfig. Or at least that's how I remember XP, Vista and 7 are slightly different.
Andi.
There is always the option of installing windows back over the previous install, it should repair any system damage as a matter of course.
put windows in drive and boot from it, when it asks where to install show it the existing windows dir (some versions will detect you have windows already installed) it should ask if you want to repair that install, say yes
