You could probably (carefully) use the paperclip method to check the psu which might help you further
Been thinking about this today... Have you got a spare psu you could test with? If your temps are always reasonable then it could be a sign of your psu beginning to fail.
What PSU do you have, and how old is it?
I have a Coolermaster V650S and iits a few years old but I only started to use it properly in the last 18 months or so.. I have a new PSU coming either tommorow or Satuday to test that but if it still happens after that I really have no idea what to do .. I installed windows on one of my other SSD's and installed newest nvidia drivers on it today and it crashed when I was using OCCT GPU test after about 5-10minutes even on a fresh install and different ssd.
Is that PSU plugged into a surge protector?
PSUs do eventually fail and I do suspect yours is an issue, but I suppose we'll find that out soon enough!
I have a similar issue to you, I'm not entirely sure what the problem is, but I figured it might be heat issues like the others have said. So I've made sure my PC is well ventilated, I removed the front cover from the case, I've put on a customer fan curve for my graphics card, I've sped up the case fans and touch wood I haven't had an freezes or crashes yet. Though I'm still not sure exactly it is a heat issue, I think it could an issue with a USB device(Wacom Tablet), or the PSU. Stuff like this is really hard to diagnose, best of luck to you.
How is your pc now, still good?, your problems sound exactly like mine.New PSU installed, its actually the Fractal Design ION+ Platinium not a seasonic but from reviews its just as good and a very very solid PSU.
The first thing I tested with my new PSU was whether my PC could turn on and off normally and it is doing that fine.. I added all my components + my GPU and my PC starts and turns off just fine where as before it would take multiple attempts to even boot.
The real test now is to wait around a day and see if it crashes during gaming etc, I just ran heaven benchmark with no issues and my GPU was running at a max of 60C so all seems good so far but even on my old PSU it would still run it just fine sometimes..
I really hope this PSU changed has fixed it and the fact that it boots properly now without having to press the power button 10 times is a good sign.. also the clicking noise that I talked about has good away so that was 100% my PSU as well.
