PC restarts when gaming
12 Mar 2003
Glasgow
At breaking point here, games keep crashing on me, otherwise my PC runs fine, can be a couple of minutes in to a game but eventually it crashes and the system reboots.
Specs are....
Ryzen 9 5900X
RTX 3070ti
Asus ROG strix B550-e Gaming mobo
Corsair Vengeance RGB Black PRO 32GB 3200MHz
Corsair RM750x PSU
Corsair H100i Elite Capellix AIO.
Temps on the CPU seem fine, never go over 80c
Graphics card draws about 300w max, doesn't overheat.
Have tried turning PBO off.
Have updated Bios, Chipset drivers.
Have done a clean install of Graphics driver using DDU and tried older drivers.
Have ran memtest and let it run for 4 passes, all ok
Separate power cables used for GPU
Still the same result....any ideas?
Can't help thinking it's a PSU issue, although 750watts should be good for my setup it just feels like there might be power draw spikes during gaming that's causing the restarts. Got a new 1000w PSU being delivered on Saturday, might seem a bit crazy coughing up the money without checking other things but I would be using the old PSU for a build I'm putting together for my son, so no great loss if it turns out the PSU is not the issue.
Try locking the CPU frequency to 4.2ghz all core or turning off the CPU boost clock altogether and see if it still crashes / reboots.
If you underclock the card it lowers power draw too (could try half clock), so if that's the problem it should help, but like you say, I'd expect it to be enough.
On your board do you have any led readouts when the restarts happens, any red or yellow led's that happen to light up, in regard to the restarts, does the pc just boot back up or does your pc shutdown and you have to turn it back on?
i have a friend that has a similar setup to you but with a 10700k instead, he's on a similar 750w psu and has no problems, even able to overclock his gpu a bit.
which games in particular are you getting issues in?
I have a Q code display on my motherboard, will need to try and see of it changes to anything when the restart happens , bit difficult as the PC is under my desk.
When it happens the PC reboots as normal, its like the reset button has been pressed, only difference is that whatever game I'm playing the screen goes black for a few seconds where you can still make out shapes of the game you were playing....if that makes sense, then reboots as normal.
Happens with multiple games, High on Life, COD MW2, Fortnite to name just a few
I had that years ago. It turned out to be a wire arcing to the case as I'd removed a hardwired case fan and not properly taped it up.
Make sure you have zero dust in it as well as in the PSU. All cables must be really well seated, double check.
I'd be very surprised if it didn't get resolved with the new psu
Even though I ran Ramtest could this issue be a Ram timing issue? I'm using Corsair Vengeance RGB Black pro 3200mhz, 4 x 8gb sticks, the motherboard website doesn't have these listed as compatible but the Pangoly site does....have yet to try it with XMP off, take it if it worked at stock then the issue could be with the memory timings?
It's always worth a try running with XMP off, but make a note of your settings. XMP can change more than just timings (it can even change non-RAM related stuff), but it's not uncommon that the settings are too optimistic for 4 sticks.
For my old SFF set up, I ran an undervolted 5800X and an undervolted 3080 FE with a SFX Seasonic 650W PSU. I too had random reboots, so replaced it with a SFX-L Silverstone 1000W PSU, problem solved :D
Bit of an off topic .... is it true older psu's struggle more with power spikes, even if they can deal with total load?
Yeah, my understanding is that older designs (like 10+ years old) find it harder to cope with rapid switching and if they don't trip, it can lead to more ripple and impact the 3.3v/5v rails, but the better PSUs can still handle it without going out of spec.
Of the more recent PSUs, the only ones I know of that struggle are based on the Seasonic Focus Plus Gold (replaced in 2018, I believe).
Looks like the new PSU resolved my issue, played a few games for a couple of hours with no issue. Don't know what the problem is with my other PSU which is only about 2 years old, when I was playing the games today I had MSI afterburner running and was keeping an eye on the wattage and temps of the CPU and GPU...CPU seemed to stay below 100 watts most of the time, few times it went up just over 100w, GPU ran just below 300w most of the time, temps stayed nice and low on both....my 750w PSU should have handled that no probs.
Looks like the new PSU resolved my issue, played a few games for a couple of hours with no issue. Don't know what the problem is with my other PSU which is only about 2 years old, when I was playing the games today I had MSI afterburner running and was keeping an eye on the wattage and temps of the CPU and GPU.,..CPU seemed to stay below 100 watts most of the time,few times it went up just over 100w, GPU ran just below 300w most of the time, temps stayed nice and low on both....my 750w PSU should have handled that no probs.
yeah a bit odd your old psu was playing up, as you say 750w should have easily coped with your setup, either the gpu was spiking under heavy load or perhaps one of the rails on your psu was starting to drop to a point the pc was doing things it shouldn't do, happy gaming never the less
I think that answers your question turbot.
