PC Specs (again - sorry)
18 Feb 2006
Hey, just thought about buying a cheaper PC, so that i can get a monitor..later on.
I'd like around a 6800 GS and at least AMD 64 3200 (at very least).
Budget is around £510.
This includes: Motherboard, CPU, GFX Card, PSU, RAM, HD (if its less at finish)
Sorry for the re-post :(
Regards,
Adam
hehe, i liked the specs..just i wanna try spend less..to save for the slight modifications later, like a new graphics card in the next 2 years or so...and also a new monitor soonish. Thanks if you can mate. Hopefully around AMD 64 3500 ;) Cheers.
CP-147-AM AMD Athlon 64 3500+ Venice 90nm (Socket 939) - OEM (CP-147-AM) 1
£109.95 £109.95
GX-056-XF XFX GeForce 6800 GS Extreme XXX Edition 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-056-XF) 1
£124.95 £124.95
CA-005-HP Hiper HPU-4K580-MK Type R 580W Modular ATX2.2 PSU - Black UV (CA-005-HP) 1
£52.95 £52.95
MY-005-GL GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL) 1
£54.95 £54.95
MB-101-AS Asus A8N-SLi SE nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-101-AS) 1
£69.95 £69.95
Subtotal £412.75
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £8.95
VAT £73.80
Total £495.50
No money left for HD unfortunately. I assume you dont need a case either as you didnt mention it. :D
Depends what you mean by good. You get a 1 year warranty with oem via ocuk compared to a 3 year warranty with the retail version via AMD. You can get the 3500+ oem, or you could go for the 3200+ retail. up to you really.
Well, considering theres not much price difference between the 3500 and the 3700 (retail) is it worth the 3700?
Ah k..no speed related things then? So basically...you have to use the £20 difference to buy the fans etc?
Gaming, Personal Use (no..not that :p) I can Spend £510ish Max. I want it to last quite a while and have a good Graphics Card..to play CoD 2 smoothly. Also..if possible have it between £400-500 so that way i can consider a monitor ;). or a HD
