So when you do a cold boot what happens? It logs into Windows and goes straight into sleep mode?
& What are your specs?
mash F8 when rebooting and boot into safemode.
just goes to show, Hybrid sleep is rubbish![]()
Get latest bios for motherboard as well.
No, it tries to load, dies, tries to load, dies. I see no display and usb ports aren't on
So it doesn't even POST? Thats a completely different problem.
You tried clearing the bios?
How do I clear the BIOS, and no, just when it should POST, it dies and tries to boot again
There is usually a jumper on the mobo somewhere to clear it, I used to get exactly the same problem but that was from overclocking too much it would just keep restarting before anything was displayed on the screen.
Would underclocking my RAM from max of 1066MHz to 667MHz cause this problem?
No underclocking would not cause a problem at all. Clearing the CMOS allways cured my problem so i would try that.
I've cleared the CMOS, doesn't work
Could be a faulty motherboard or PSU then,
Do you have any spares that you could use to test with.
Yeah clear cmos, not bios lol. Clearing the bios would end up with a dead motherboard.
If clearing the cmos doesn't work, then its probably a hardware fault.
oh this is the HDD drive on its way out syndrome:S it happend to my mates PC![]()
