- 18 Oct 2002
can anyone help ive had this problem for a while now. i do work in a hot room but only this pc crashes. ive got speedfan installed, see screen shot. ive got loads of case fans running as well.
wizardmaxx said:Try and check the temperature of the ram modules, or replace with ram you know is working.
wizardmaxx said:Use a temperature probe or touch the ram chips with your finger. If your skin comes off then they are running too hot.![]()
Aekeron said:Try re-seating your CPU and applying new thermal paste. It could well just be that your ambient temp is so hot that the CPU cooler can't cope.
wizardmaxx said:Worth a try, but 59c in bios is not excessive for those chips imo.
wizardmaxx said:Had another look at your first post and your 5v rail seems 'kinda on the low side if u know what i mean' . Try a different psu. -12v looks suspect as well.
Aekeron said:I didn't even notice that - if it's an accurate read-out, that's highly highly dodgy![]()
