Hi Guys and Gals,
I know there are quite a few posts about the 805 chip but I would like some buying advice if possible from you people in the know
I need:
Chip (805 obviously)
Motherboard
Memory
PSU
I have a cheap Watercooler already which should allow me to clock it some even though I may not get the max out of it.
On the motherboard front is it worth going for the new ASUS one which supports Conroe ? or do any of you know of any Mb manufacturers that will/can update their existing boards BIOS to handle Conroe ?
I currently have a Corsair CM512-3200C2 ram, would this work with the 805 and LGA775 mainboard until I got some new memory ?
Thanks for any advice.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
I need:
Motherboard
Memory
PSU
