People thoughts on Akasa Zen
Yewen said:
Jeantech Phong I, its very similar to the Zen so far and has the same feature list. The Phong II is a lot worse, to many features for the money, and its to expensive.
I have not mentioned the front intake as I have not looked at it, the other cases I got from another source took priority over this one, and I had a Sugo Evo to build up aswell. :)
Will find all these things out tommorrow for people, just give me time I only ordered the case 30 hours ago ish after reading this thread! :o
Ah yes, strangely enough I have the cardboard box of a Jeantech Phong! :D
Ok, no rush and I do appreciate you posting so soon after you received it! :)
You have the box, how about the contents of said box?
Oh and I am not moaning, but people forget I have a life of the forums, sort of...
Literally just got to go but here is a piccy.
Sadly not, I was at one point going to buy one but decided against it. Instead I purchased a second hand Lian Li PC-50, which strangely arrived in a
Jeantech Phong box.
WJA96 said:
Amended for truth ;)
:D
Anyways, Thanks for the picture Yewen, doesn't look all that great but I would assume Akasa have tested and researched it. I guess the fan would pull in air from other small gaps in the construction of the front. But it is somewhat worrying.
Let us know when you get chance to do some performance testing as that will tell us just how good it is at cooling, even with the limited air gaps in the front. No rush though, will be a while before I need to purchase.
Dr Jones said:
Hmm... is there no filer then? :confused:
Filter?
Neon said:
ill stick with my akasa....eclipse.
Pointless post really, completely different league of case.
Not built in it yet sorry, but I can tell you from looking at it the cooling is going to be very good for a £30 case. :)
