Pes 2010
Anyone find the controls on this demo sluggish? Mine feel far worse than 2009.
Not only that but v-sync is obviously broken in it (its ticked but greyed out) as I get terrible tearing all over the shop...
No tearing as such here, but I know what you mean about it feeling a little sluggish. It's like it's running *just* a bit too slow. Still played way too much of this demo already though!
Im getting the same thing.
It is not that it is BAD, more annoying as it is playbale but it is as though if it was that little bit better it would be perfectly smooth.
What O.S / VGA setup you running?
Im on Windows 7 / Radeon 4850.
Loving the game though.
Mine runs great IF I close the browser :S
That said, I'm really enjoying the game so far! Looking forward to the full release!
Its miles better then 09 for some reason 09 ran way to fast on my pc it was like playin it on fast forward lol.
Its a bit easy tho
And why have thay turned off commentary on the demo thats just silly
I am running the demo on windows 7. Using a ps2 control pad through a converter - previously for all types of games including pro eveo this has not caused any problems. However when i go to change the control options in game some of the buttons are not responding - anyone else having this problem?
I tried out the demo. I must say I was impressed. I will be getting FIFA 10 on xbox 360 and PES 10 on PC. Didn't like FIFA 10 on PC tbh, PES 10 much better on PC :)
One thing though, is it because its demo you cant set resolution to 2560x1600? or is it like that usually?
Anyones pre-orders shipped yet?
Wondering if they are being posted early owing to strikes.
Mine should hopefully be dispatched tomorrow.
I have high hopes for this after the demo.
I just hope the online play is upto scratch.
Oh well, should have it this morning if the Postman isn't a lazy bum.
I'm getting like a frequent micro stutter at what seems at regular intervals with Vsync on, it's really annoying. If I disable vsync I get tearing. Its like as you're playing, it will skip a couple of frames in the animation. This is on PES 2009 btw.
Any ideas? Also, it seems CCC doesn't work with PES, can't force AA or anything like I could with the Nvidia control panel!
