- 4 Jan 2004
- ¯\_(ツ)_/¯
I use cillit bang...
I use cillit bang...![]()
The product he sold me was
3-in-1 Multi Purpose Oil
LOL ! Toothpaste is supposed to be a very good substitute for thermal paste as well I hear![]()
Acetone should not be used to clean cpu's. It does leave a residue when evaporated (a white film). It can also eat away the silicon chip! Yes, they tend to now use an IHS, but risk still remains. IPA is the best stuff to use.
That all depends on your CPU and whether or not it's overclocked.
Your question is like asking is £20 good for a watch - depends what sort of watch it is!
I have an i7 920 that idles higher than your max temp!
Ok, i might regret it but i used the petrol.
New cpu cooler on as i type working well.
temps for idle are 32c right now, lowest was 27c and highest 40c
are those temps about right, i, actually very happy, it's so quiet.
AMD 955 & not overclocked.
P.S i am not trolling i got the product mixed up, it was actually petrol not that oil 3 in 1 thing
anyway it's a lot quiet, only problem is my side panel don't fit back on as cooler so big!
You can also get IPA off ebay very cheaply if your chemist does not stock it...
