Phantek T30 - one fan to rule them all?
I'm still running 9 of these on the MO-RA3 and so far no issues, i don't hear a buzzing noise at 1200rpm or so, they are literally dead quiet.
Screws are available from a certain online retailer, i just got a few packs for spares. It's unfortunate but radiator manufacturers haven't standardised the screw hole size or it would be so much easier.
Thats good to know - my screws are on the way from China - only place I could find black M4 30mm with philips for a reasonable price (online).
Ah fair enough, i went with the Hex heads and counter sunk for a flusher fit. Think i paid £6 for 20.
sourcingmap M3 x 35mm Metric Hex Socket Countersunk Head Screw Bolts Black 20PCS
Mine arrived and tested them yesterday. When on the 3000 RPM setting, they make a noticeable clicking sound when at 600-1000 RPM. Doesn't seem to occur with the 2000 RPM setting.
Will do more testing over the next week or so when I have time - anyone else experience the same?
Using a Aqua Computer OCTO for the fan control.
