Phanteks d30-120 question and pwm fan hub
Keep in mind fan amp rating is running load, not start-up load.
Motors draw 3-4 times more starting up.
Only company I know of publishing running and start up is Nidec.
Their specs for Gentle Typhoon 2150rpm are 123mA running and 530mA start up. That's more than 4 times more at start up. This means 4 running fans rated up to 1.23A each draw up to 4.92A starting up! Sure, it's only a second or less, but that's a huge load on mobo fan header.​
Ever notice that peeps saying they burned out a fan header almost always say they noticed it when starting up system? ;)
guys when i try and set my fans to 35% percent they all stop and make a weird noise like that setting is to low for the fans? i have to set them manual and to 50 percent? any help would be appreciated
I'm assuming you have Phanteks T30-120 fans with 3 speed range settings, so what speed setting are you using?
Hybrid mode (up to 1200rpm with a fan stop below 50% PWM)​
Performance mode (up to 2000rpm, recommended for general use)​
Advanced mode (up to 3000rpm for maximum performance)​
The default setting is Performance mode.​
No buddy I have planters d30-120 fans are they similar?
