Hi Gang
Today we announce pre order availability of the new EX5 case from Phanteks
The Phanteks EX5 is a new chassis designed with a compartmentalized structure. This layout organises key components into dedicated chambers, ensuring each receives a direct flow of fresh air. The EX5 will come in multiple variants, including options with integrated AIO liquid coolers and built-in LCD displays.
The EX5 moves away from the boxy, ‘fish tank’ aesthetic and presents a bold, creative way to showcase a PC build. The unique layout optimizes cooling efficiency by directing fresh air precisely where it’s needed and expelling heat more effectively.
This effective airflow design reduces reliance on excessive fan setups, allowing builders to achieve excellent thermals with fewer fans.
It’s built for high-performance hardware, easily accommodating large GPUs and a dedicated 360mm radiator. The strategically placed fan behind the mainboard effectively cools the VRM and RAM, while also directing heat from the GPU away from key components to maintain optimal temperatures.
The EX combines generous interior space with intuitive cable management for a clean, effortless setup. To complete the sophisticated aesthetic, vibrant ARGB lighting wraps around the chassis for a clean, modern finish. Synchronized via the Nexlinq app or your mainboard, the EX-series offers a polished, efficient build that stays as cool as it looks
We have stock inbound and will be running a special introductory price from 08.09.2026 until 30.09.2026 when the product officially launches and units start shipping.
The introductory price will be valid for all purchases made in this timeframe and will be the best discount we offer on this new product.
Phanteks EX5 High Airflow ATX Chamber Case - Satin Black - CAS-PHK-08413
Introductory Price - £86.99
Normal Price - £95.99
Phanteks EX5 PLUS High Airflow ATX Chamber Case with 360 AIO - Satin Black - CAS-PHK-08414
Introductory Price - £114.95
Normal Price - £139.99
Phanteks EX5 MAX High Airflow ATX Chamber Case with 360 AIO - Satin Black - CAS-PHK-08415
Introductory Price - £174.95
Normal Price - £199.99
EX6 Soon™
