Phanteks PSU
still a bit of a birds nest,, but nowhere near as bad as it was before..
That price! Looks much smaller than my P2 though, problem is when you have such a big PSU you feel the need to put load on it, which means more expensive hardware! Hopefully she'll last you for 10 years.
The only thing I may get now is an RTX2070 and apart from an SSD upgrade that will be it for somtime
With current pricing the GTX 1080ti might be the better call, something to keep in mind if you decide to upgrade. Quick question is that two motherboards/cpu/ram into one case? If so how are you powering them off of one PSU?
W. Quick question is that two motherboards/cpu/ram into one case? If so how are you powering them off of one PSU?
you didn't pay much attention to the image of the PSU doogles or check the link to it ;) , or look at the sig
why do you have 2 systems in one case? is it just to save having 2 computer towers or serves a different sort of purpose?
the psu is nice, didnt think they made units only cases?
yes just to save space of having 2 pc cases.. technically its way more expensive this way..
