Phenom ii x2 555 to Pentium G440
10 Sep 2007
Hi
I am currently running a Phenom ii x2 555 its AM3 but on AM2+ motherboard so DDR2 and SATA2, so overdue for an upgrade several years ago. I am looking at new Motherboard, RAM and CPU and possibly cooler (currently have H50). I can keep my GPU,PSU, case, SSD for now.
I don’t want buy into DDR3 now so basically only option is Skylake which is fine (Haswell-E is too rich for me). I want to go for reasonably decent spec, thinking:
i7-6700K
£150ish motherboard
2x16GB of RAM (to leave two lots free for later)
Unfortunately, I don’t have enough money for everything I want all at once. Since the CPU is the main cost I was debating getting the rest but throwing a Pentium G440 in at around £50 for time being, then swapping out for i7 in a few months.
I’d would be grateful for any thoughts or suggestions on this, is this a good strategy based on where I am to where I want to go, or should I wait until I have saved up enough and do it all at once?
I would get a Core i3 6100 and a £100 motherboard or a Core i5 6500 and a cheaper motherboard.
Thanks, I’ve looked at this you may be right about i3 and cheaper motherboard and if I stick to 16GB RAM I can get a good upgrade for £300ish.
Tried unlocking your phenom to a quad core?
It unlocks, but won’t boot, I’ve also tried each combo of 3 cores, none work.
wouldnt the AM3 mobo support a FX series processor such as the "Piledriver FX-8 Eight Core 8370"( https://www.overclockers.co.uk/amd-...hz-socket-am3-processor-retail-cp-381-am.html ) a bios update may be needed but performance would be night and day compared to the phenom dual core !
Its AM2+ motherboard, the Phenom II x6 is best I could get and that’s old as well.
Honestly wouldn't bother with a dual core unless you're doing very light gaming, even if its just temporary.
I would wait the few months and go straight for the i7, or compromise and get an i5.
Wait for Zen? 8 cor processor with core performance supposedly around haswell/broadwell, could bring the prices of skylake drastically. Its all specualtion of course, but might be worth waiting until the end of the year for
Could raise them like Bulldozer did :p.
I jest, but chances of any price movement are low. If Zen's good, it's not going to be some bargain price CPU.
Have you tried feeding it more volts after unlocking it? I'd try 1.5v as a test.
A well clocked p ii x6 is still a good chip.
I messed about with it a lot back when it was new. Gave up after no joy, no real complaints though its done me quite well for over 5 years.
I think your plan sounds ok OP
The time on the dual core chip would be the perfect time to catch up on those old games you have in your steam library that you never got the chance to play.
If the dual core does your head in, then nothing stopping you grabbing an i5 instead of the i7.
I would save up and wait for AM4 and Bristol Ridge then look at Zen.
16Gb DDR4 DIMM's are pricey as hell right now, but Samsung have just started production of 10nm chips so prices should start to fall.
Thanks for the responses guys,
I have actually decided to bide my time for now. I have some other big expenditure come up so I am thinking wait 3-6 months and then get go straight in to i7.
Events have overtaken me!
My computer has been crashing in window 8.1 after about and hour, whether gaming or just browsing. I assumed it was software but have been hoping to manage until I upgrade to save on the faff of a reinstall. However, the problem has spread to my Linux installation on seperate drive but is much worse sometime crashing after.
Long and short is I am not waiting so I have raided my "in case of emergency fund" and ordered the i7 6700K and an MSI M7 motherboard, I stuck to 16GB RAM and threw in a Samsung M2 SSD instead.
CPU and motherboard have already arrived, couple of days tomorrow for RAM and Tuesday for SSD.
This will be one hell of an upgrade.
That's a hell of an upgrade, you probably won't get a similar experience for quite some time with the stagnation in performance increases!
