photoshop/permier pro build
7 Jul 2008
Newcastle upon Tyne
This is my build for a photoshop/premier pro rig Based on my budget
I already have a 8gb memory stitch and sad drive
Does a cooler come with the Ryzen and if not which would you reccomend
My basket at Overclockers UK:
Total: £730.00 (includes shipping: £11.10)
if You look at my post again I say I already have 8gb and then there is 8gb on the shopping list
Re the i7, of course it will be better. It’s should be at nearly twice the price!
Total: £114.49 (includes shipping: £10.50)
Much better board in every way and it's replacement !
Ryzen does come with it, and recommend the ryzen 2600x for its extra speed !
But intel would be better
You'll also have to manually overclock that Samsung d-die from 2400hz to 3000/3200hz
Thanks for the mobo recommendation
Would not bother over locking the memory, not into overclocking. Why do you say I would have to overclock?
Intel may be better, however bang for buck which intel would be better than the AMD.
Don’t get me wrong, money no object intel all the way (I have always bought intel) however some on here have recently made me aware of the ryzden and it’s value over intel.
Probably the closest intel would be the i5 8600k which is £50 more but is it better?
Total: £693.64 (includes shipping: £11.70)​
Ryzen performance is linked heavily to ram speed
I see, I am very much an AMD newbie
You spec is also interesting. Especially the Radeon RX 5700, I was under the impression remixer pro like cuda cores
The case looks nice and it’s micro atx. Would that mean a cheaper mobo
What’s the difference between B450 and B350? I should look this up
Bit of a lie, the case can handle 2/3slot mobo so in-between itx and mATX .
Also, itx is normally designed better then mATX counterparts :)
Intel
Total: £834.63 (includes shipping: £11.70)​
Rx570, as cheaper, performs just a little bit less in Adobe and cheaper , also 3 free games will end of this week !
Difference between b450 and b350 Chipset, store MI .
And that b450 are setter designed boards . And the Aorus is one of the best mATX/itx
So intel quite a bit more
Appreciate your thoughts
However it’s easy to get carried away and get better components which all add up :)
Also the Gigabyte MOBO is out of stock.
Whats the alternative?
Azrock B450 Gaming ITX £120
Gigabyte AB350N Gaming ITX £105
Azrock Fatal1ty AB350 Gaming ITX £105
Bit confused by all of that
Are you saying your choice would be the Asus Strix, if so that's out of my budget
So would I just be better finding the Gigabyte somewhere else?
