Helicopters are easier to understand. They don’t actually fly, they’re just so ugly that the surface of the Earth repels them upward in disgust.
To be fair, they should just screw themselves into the ground.
I love flying. Some how you have made me worry for my next flight, when ever than is.I think you have to come to the terms with the fact that your fear of flying does not stem from the technology or chance of a crash. It is very easy to understand that plane travel is incredibly safe statistically.
The subconscious fear you have of it, most likely comes from the WAY you could possibly die...and by that i mean that you would likely know in advance that you were going to die.
In most other accidents in other forms of travel, death comes pretty instantly and without warning. You could argue that isn't the case with a boat sinking, but on a boat you always have hope you could survive/get rescued.
On a plane, if it is all goes wrong thousands of feet in the air, you will be hurtling towards the ground and there is **** all you or anyone can do about it, and you know that you WILL die. In a plane, unless you are lucky and it just explodes completely, there will likely be a reasonable amount of time to contemplate your impending death.
That is where the fear comes from and is (i agree) absolutely terrifying.
Mags is Arthur Shappey.
Brilliant!
It wouldn't since air speed would be mostly unaffected by the movement of the treadmill.If you put one on a giant treadmill, at what point would it take off?
You can fix most things with money. I guess I could just buy a private plane.You can fix most of that with money
I am not good with heights but I love flying. Best bit is looking down out of the window during take-off and landing. The other best bit is the big blue above the top cloud layer. Smooth flying and great visuals.
The Mr T thread?
I had a very drunken conversation
Pretty sure you can apply this to all your conversations tbh
Some of the air crash investigation programmes and their recreated scenes are the stuff of nightmaresI think you have to come to the terms with the fact that your fear of flying does not stem from the technology or chance of a crash. It is very easy to understand that plane travel is incredibly safe statistically.
This one is a bit old, but one of my favourites to listen to with regard aircraft failures. Engine takes a bird on takeoff, carries on up and around, holds for a while then comes in to land, all on one engine. You can listen to the radio chatter as well, as cool and calm and collected as can be the whole time.
Aircraft have immense amounts of redundancy built in, and one failure will almost never cause a failure of the whole airframe.
