Just signed up for the Yorkshire Marathon in October. Plenty time to ponder the training plan! Will be my second marathon - hopefully what I learnt about hitting the wall in Edinburgh (2011) will help me.
Signed up for my first marathon - Windermere in May. Only run up to half marathons to date; pb of 1hr 38 min, so targeting full marathon time of around 3h45 min.
20 week training plan started this week....
I did Windermere as my first marathon, good luck, enjoy the scenery and make the most of it.
Don't worry if you don't get the time you want, it's your first marathon and Windermere isn't the easiest of places to run 26.2 miles.![]()
It's just a a case of building up slowly and running more often too.
Running outside is much better as well I find, nothing more boring than running on a treadmill and I know they have a hill setting but it's not quite the same as a road for me.
A general rule is to only increase your mileage by around 10% each week. That said if your weekly mileage at the moment is 5k I'd personally run a little further than 10% extra each week.
Some people find it helpful to run the whole distance if not more in training (for a half-marathon or less at least) but I think you'd also be fine if your training runs went up to 11.5/12 miles.
How often are you running at the moment?
I'm guessing they are all around 5km or maybe longer given the fact you talked of running 8km previously.
I'd suggest one of the runs in that case being a dedicated long run. If 8km is the furthest you've run and it was fairly recent then I'd start from there and each week add on 1km. A half marathon is 21km so won't take long to actually increase.
The other three runs can be a mixture of a short/fast run, medium/average pace run and the other possibly a hill session.
Also, don't forget that if your running longer to reduce your pace a touch, if you don't (even if you feel amazing) you'll get caught out if running a distance you've not covered before.Unless it's what's called a recovery run (very slow, short run) I wouldn't be running the day after a long run either. A recovery run can do wonders though.
Yeah pretty much 5k's at the moment, 3 to 4 times a week. The 8k was a while ago though. So this Sunday, i'm going to reduce my pace and try an 8k again and take it from there. Should give me a fair idea of how close to a 10k I am.
I am also planning to start eating a little better as I need to drop some weight (14 stone, 5'10", want to drop a stone off that) which should also help.
Thanks again for the advice, not really been getting anywhere with my running for a while and i'm hoping the GNR is the ideal motivation!
No problem.
Just to add as well, unsure how long you've been running the 3/4 times a week but the frequency is there so it's down to targeted sessions for improvement then, a long run and the weight loss will work as well.
Do you ever run with others at all? If not then I'd also recommend joining a running club possibly or looking at the Sweatshop Running Community if you have a local store.
It's amazing how much running with others improves your running. I run with 90+ people on most Tuesday evenings and it's nice having someone potentially a bit faster than you as a target, there's also the sound of people behind you that keeps you going when you might otherwise stop.
Good stuff, I promise you'll improve plenty when once you've been running outside and with others as well.
What's your local Sweatshop out of interest?
Nipple Rub, Vaseline or medical tape as mentioned. The cause will a combination of the material of your top, embroided logos if running in a footy shirt and the wet.
Had a friend who once did his first track session in a white t-shirt when it was raining. He had two very red lines streaming down his top once he'd finished. He didn't even notice until he'd done either!!! That lad was bloody fast as well. He did a sub 3.00 marathon at his first attempt at the distance and no longer runs anymore.![]()
