Miles rather than pace. No issue with the long run being on the Tuesday to be honest and if it helps you fit in ParkRun and be well rested for the longer runs then I'd keep that as it is. Obviously as the HM approaches you'd just need to shift the running around a little 2-3 weeks before as not to end up having a long run scheduled 5 days before.
If you want to incorporate an extra day I'd say Thursday is probably best as that would then be:
Tues - Long Run (Build up to 14-15 miles)
Thurs - Middle distance run (incorporating hills if possible)(Start at 5-6 miles and build up to 8-9 in line with the long run.
Saturday - ParkRun / Faster short run (3-5 miles)
Gives you a day of rest inbetween each one and two days of rest before the long run. If you wanted or felt like adding any more it would simply be a recovery run after either of the sessions listed. Ran slower than long run pace and only around 5k at most really.
Including the hills in your schedule would be a case of either incorporating them occasionally on the long run (distance permits the 2 miles there and back) or waiting until the middle distance run is around 6-7 miles and incorporating it here instead. I wouldn't do them too often to begin with either, just remember to take things slowly, the progress will come and you'll gradually get stronger and fingers crossed stay injury free.
