- 5 May 2004
- Northern Ireland
Gave my legs a good roll out last night and it seems to have helped. I guess just having a cool down walk isn't sufficient post run.
Went out this morning. Hit the 5mile mark which is near where i was finishing so decided to sprint for a bit. Managed about 0.1m before giving up and my heart rate had hit 192.
Looked on strava and it showed as a pace of 6.02/mile. How some of you guys hold that for a whole run i'll never know, i thought i was gonna black out!![]()
I see that Dan posted a run on Strava and keeping it within a certain HR range. As someone who hasn't tried this before, been more concerned about my pace, how do you think I should approach that? As discussed a few times, I've a rather high HR while running and keeping it under 140 (Dan's example) would be impossible for me. SHould I aim to try and keep my HR 5-10 BPM under my normal rate and bring it down in interments?
How did you find your pace altered from usual Dan? I'd assume you were slower than on your usual runs?
Yeah i've accepted i'm too fat to get decent times, putting in too much effort really knocks me off. My heart seems strong in that i dropped from 192 to ~160 pretty quick so happy with that.
I broke my nose as a kid and could only breathe through one nostril between about the age of 5 and 20. I seem to really struggle with breathing when i go above a certain level of effort and i don't know if thats a cause and my lungs haven't developed as fully as they should.
My goal now is to just drop the 20kg i've put on in the last 18 months. Going from 90kg to 110kg has really killed any speed i had and definitely has lead to more niggly injuries.
20Kg is about what I need to lose as well! Currently 108 and falling very very slowly.
If you are breathing heavily then you are running too fast for an easy run. Breathing rate will also increase massively as you get faster as that is the main limiting factor in speed (e.g., VO2MAx is the uptake of oxygen in your body and pretty much defines performance). If you your breathing rate goes high then you need to slow right down, expect perhaps once a week when you can let it go a bit more..
On normal runs, my breathing is absolutely fine. I very rarely struggle and i always keep around the 9:30 to 10:30 pace. Sometimes though i'll try and just finish off with a quicker mile around the 9min mark and even that small increase in speed kills me. Even when i was running around 8:30 pace when i was lighter, i could run at that pace for 1 mile or 10 miles. If i ever tried to go even a bit faster i hit a wall.
