I've been happy with my new Brooks Revel 3 trainers but spotted Adidas Ultraboost 19 for £59 in my size and couldn't help myself as everyone raves about them so much.
Probably not a good idea to mix trainers so I'll just wait until I wear the Brooks out which shouldn't take too long at my weight!
Point me in the direction please? I love Ultraboost for casual. Have pretty much stopped running in my Ultra 19s now
It's actually a good idea to mix them up. Not only does it prolong their life but it helps your legs as one pair might "work" slightly different areas so you're not getting unbalanced or putting some areas under extra stress![]()
@D.P. et al
Would greatly appreciate some trainer advice. After a gaint test iv been running in Brooks Ravenna 9's (https://runrepeat.com/brooks-ravenna-9) the last 18/19 months. Iv been wearing them for walks too. Probably run/walked about 1600-2000 miles in them. The underside of them are a tad worn now. Some bits are 100% worn (like a bald tyre) and some bits look like they still have 80% 'tred'.
How often/how many miles should you replace your trainers?
Would the Ravenna 10's be appropriate replacements? They are the same weight, same heel/foorfoot height and are 'stability', medium arch' and 'overpronation' as my 9's as per the FACTS on runrepeat. So another gaint test and store visit aside, are these an ok like for like replacement?
Looking on runnersneed they split it between trail and road trainers. Assume the big difference is the tread but not sure which is regular running trainers sorry.If it's compact gravel then regular running trainers will do, especially if there's pavement involved too.
I have some inno-8 gym trainers and asics for my touch rugby boots.
the trainer lasts the same number of miles ... if you have a new identical/similar pair in resereve you can try them occassionally to see how bad the old ones became,It's actually a good idea to mix them up. Not only does it prolong their life
Yeah, i tend to have 3 options
1 - Long runs where i'm out over 2 hours. I'll wear a hydration vest, i've just got a cheap one from Decathlon, it has a 1L bladder built in.
2 - Middle runs where i still feel i want a drink if it's hot, i have a running belt which has a soft flash in it which is around 400ml. Think it was a Salomon one for about £15
3 - Short runs where it's boiling. I'll tend to just carry a bottle, although like you i really dislike running with a bottle in hand.
my rationale for sequential use ... as soon as you start using them (like car, or bike tyres, rubber gloves) you stress the elastic material, and breakdown, oxydation starts, leaching of oils, and, that contributes to ongoing degradation, even if you are not using them ... hence sequential use gives longer lifespanI always thought there was a belief that wearing 2 pairs in parallel would last longer that 2 pairs worn one after the other.
