- 27 Jan 2018
- Uk, Southwest
Hey Fellow Overclockers,
I am a bit of trouble with my gtx 970 graphics card
Inno3d GTX 970 OC 4GB GDDR5
Setup - Intel 6600K CPU - MSI Z270 BOARD- 600w Corsair PSU - 16GB Corsair DDR4 -
Tested my RIG with a mates GTX 1080Ti 11gb , with no issues , so its definitely the card not the rig.
the issue i am having is - and what i have done:
NOTE: All Steps are carried out while plugged into PCI Slot of a working motherboard with working Power Supply
Install both 6-pin cables (2x 6pins) *NO POWER - NO BOOT*
Install 6pin cable into only port A (1x6pins) *BOOTS* Message on screen to install other 6 pin plug*
Install 6-pin cable into only port B (1x6pins) *NO POWER - NO BOOT*
so by trial and and error the issue seems to be the 6 pin port B or some capacitor/resistor/ etc etc that links to it. i have included pictures with this post of the board , with a series of parallel capacitors and mosfets.
can anyone make end of this , and inform me of what might be causing this , it powers up and im not ready to give up on this yet ? any ideas chaps ? also there is absolutely no sign anywhere on the board of anything blown burnt or faulty
thanks in advance
IMAGES:
https://ibb.co/ddi1Bw
https://ibb.co/dZA6Bw
https://ibb.co/fuecJb
https://ibb.co/bZZBdb
thanks in advance
IMAGES:
