Please Help - GPU wont fit.
7 Jan 2012
Please Help - Cable Problems now.
Currently doing my first build. I have everything in its slot and all seemed good.
Cooler Master Elite 430 Is my case
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Is my GPU
The motherboard is fasted in place and the gpu is the last thing to go in. But it will not seem to fit. I only have 1 Slot on motherboard that will fit the card.
MSI H61M-E33 Intel H61 (Socket 1155) DDR3 Motherboard **B3 REVISION**
Is the motherboard.
The GPU is 0.3mm away from being in its slot. The right hand side of the pci slot can accomdate it no problem but that small other left hand side of the slot just will not let it in. The card is going into the correct slot but i think the plate that holds the Mboard spacers is blocking it from clipping in.
Please Help, what can i do.
DELETE THIS THREAD AND JOY TO THE WORLD IT FITTED.
the metal that holds the DVI connectors was slightly bent from my first attempt. so i fixed it omfg so happy sorry.
Could it be the card is going on wonky, or the back plate is not lining up properly and not going down the edge of the board!
Sometimes it can be tricky to get the card slotted in. You have to push it quite hard against the expansion slots area to the left and then slide it down from there. If you are having trouble with the small area of the card interface then try and get that in first. It could be that once the larger section is in place it is keying itself in and wont allow movement to the smaller section.
Edit: Looks like you've resolved it now.
Ok new problem I literally have no advanced my build at all in the last 1.5 hours. All i have left to do is plug everything in its slot.
But the problem is i have no idea what goes where is there a good guide for this? The system build guide on forums doesnt seem detailed enough at this part.
The GPU has space for a 12 pin plug from the PSU. However my PSU was supplied with 2x PCI 6+2 pin connectors. What do i do here?
Indeed put both in there, are leave the extra 2 pins hanging loose.
Don't forget the extra 8 pin for cpu power.
Okay i think i have the following done
Main Motherboard power - connected to PSU
Main CPU power (4pin) - connected to PSU
Red cable going from Hardrive to slot on motherboard that read "Sata"
Red cable (identical cable) going from Optical drive to the only place it would fit which is right next to the sata port.
Does this look okay?
also so i use both 6pins on the GPU thats means both are plugged into each of the PSU's 2x "PCI power" Slots?
Thanks for help guys really appreciate it
Yeah that looks correct!
Yeah that's right
Okay we are making some progress here. Thanks to you guys.
Now i assume both the HDD and Optical drive need to be connected to the PSU or am i wrong?
You will need them to be connected to the power supply, Using the sata power connectors. :)
I have this cable i think its called 4 pin molax cable but dont quote me on that. Anyways it has a place where it plugs into the PSU and then has 3 heads? Like 3 identical almost SD card shaped fittings on it. What is this for please, is this for the HDD to the PSU? Why does it have 3 heads.
Yes that is correct. That is SATA power. It has 3 for 3 devices. Plug one into the HDD and one into the optical drive :)
It only goes in one way round, there is a L shape one end, so watch out for this and align it properly then you'll be done!
right thats it. It doesnt plug in too far thats why it confused me a think. Its not a firm grip but its in and defo the correct slot.
I used 1x of these cables which goes from a 4pin slot in my PSU to my HDD and then to my CDROM.
Hope thats correct.
Now i have the issue of there is a 8pin socket left on the HDD do i need to do something with that or am i good to go if its connected to the PSU and Mboard?
