Right. Im just trying to work out the front panel functions slots but i think i got that. However where does my case fun plug in? It seems to have 2 head both of which could likely be plugged into each other. quite large 4 pin male and female. there is a "sys fan" slot on my mboard but it is 4pin male and tiny by comparison?
Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply
Ok this is the siutation
PSU into motherboard ( massive 20odd pin plug)
PSU to CPU (4 pin connecter near the cpu)
PSU to HDD to CDROM (All 1 cable)
2x PCI 6+2 pin cables from PSU To GPU using the 6pin heads and leaving each 2pins head dangling.
Front case LEDS and power into 1 block on the Mboard called JFP1 (this was fiddly)
Red cable from HDD to Sata port on Mboard
Red cable from CDROM to port next to the sata port
1x molax cable from PSU that plugs into ONE of the heads of the system fan at the fron of my case. Leaving the female system fan head free.
Does this look okay? If so im gonna use a few cable ties and am i ready for the big bootup when i connect monitor etc?
I would say your looking ok, one thing I tend to do before starting the system is doing a CMOS reset.
You can do this by shorting two pins on the motherboard together by using a jumper (supplied on the board) or screw driver, the manual will show location.
my mboard has USB and Audio already build in to it, im guessing these cables are for if you have extra jacks/usb ports etc at the front of your PC case?
But i do not have headphone slot or any sort or port the the front of my case. All ports are at the back and feed directly into the Mboard itself so do i need to use these?
indeed hahaha well thats plugged in thanks so much I have learned A HELL OF a lot today so quite chuffed.
The ac97 didnt have a place to go so dno whats going on there but the HD audio went in its place as did the USB so gonna refit side panels and prepare to boot XD
I assume you herd the hard disc drive ramp up and did you hear any noises from the DVD drive when booting.
Might be worth shutting down and double checking the power leads are in, they could have been moved when doing some other cabling, i have done this on many occasion.
I'm signing off now, hopefully another member will able to assist
