- 22 Aug 2009
Hi Guys please could you help me.
I am still having trouble with a rig I recently brought from OCuk.
This was my first thread on the issue
http://forums.overclockers.co.uk/showthread.php?t=18049237
To sum up I posted the rig and it was sent back with a note saying they had found no problems, but for the last few days I have still run into NO POST problems.
I have found the problem to be with the PSU connections that plug into the Geforce 295, when I encounter these problems I am, from time to time, simply able to push the connection back in (usually the 6 pin on the top + I have to leave the side off as it clashes with the connection) and I regain POST until I switch the computer off and start it back and again NO POST. The frequencies are becoming worse and I don't wish to constantly fight with the connections every time I wish to go on.
As you can tell I'am finding this hugely frustrating I have phoned up customer support and was told that there was no problem with the rig and that it must be a problem at my end (Power cord etc). I am starting to consider a refund as I don't have a working computer, the only thing they really had to do was connect all the components and that's where I am finding the problems.
Please can you give me some advise!!!
P.S. If you wish I can post some images of the rig.
