Please help me, I'm going crazy, nvidia driver failed install
26 Sep 2017
In the Masonic Temple
Hello there, starting today when saw i have an update for my 2080ti in nvidia experience, as normal I downloaded it and tried to install it only this time it said failed......
I tried custom, failed, express, failed......
Uninstall the drivers I had and the experience.
Downloaded fresh... Failed
Download experience, failed.
DDU in safe mode, tried again, failed.
Windows update, downloading nvidia 27.something. Installing, failed.... No reasons why for any of these.
Tried deleting from services, from the hard drive, from the registry. Running ccleaner.. Tried again and failed.
Please for the love of everything someone help me
Have you read up on the whole DCH thing? though usually it gives an error about that.
Alternatively try extracting the nVidia driver with 7-zip or the like to a folder, go into Device Manager and find the GPU, go into its properties and do a manual driver update pointing at the folder you extracted the driver to - then if that works you might want to reboot and follow up with re-running the installer.
I had this on my 1080ti a while back, but mine happened when my control panel decided to go loopy. Tried uninstall and reinstall drivers and it just kept failing.
Don't know if you've tried but I used ddu and disabled windows auto updates through it which got mine to install. Was a windows conflict with mine where it was messing about in the background trying install its own drivers and screwing everything up.
Thanks for the reply.
It won't even install windows update version, that fails too.
it says generic vga device in the device manager. And when I try to update it, it just says Windows failed to update this device. No explanation or error code
In gpuz all the boxes are just blank also....
So weird to be playing a game and then such a massive problem to happen just updating the driver
As someone mentioned above - look at your anti-virus. Disable it temporarily and install the drivers.
I got into terrible problems with Commodo AV at one stage and Nvidia drivers, and had the exact same behaviour as you are seeing.
Might be worth a try, if you haven't already done so.
Maybe a system restore back to an earlier time when it was working, to reset the registry and then try again.
Sorry just clutching at straws.
The other thing I would try is to disconnect any networking. Run DDU again. Reboot and check device manager to see what it says. Failing that you are in to hacking the registry and that could cause more damage than it solves.
Two things to try:
1. Move the GPU to another slot
2. Take the GPU out and put another one in. Set that up, make sure you go through at least two reboots afterwards, then put the 2080 Ti back in.
