Please Help Me!
14 Jul 2020
Hello everyone, I have been looking at getting a custom PC from overclockers for quite some time. The PC I have made can be found here. If you look at the image, it looks like it has watercooling. I am just wondering whether that is true, or if it is just the image. If it does not come with water cooling do you know if there is anyway to add it?
Thanks in advance
EntropicPanda
@EntropicPanda the Ryzen build for the same price is much better I would say better graphics for a start but no AIO but this can be easily added afterwards. might be worth looking at
Also to back this, stock Ryzen coolers are pretty efficient if not overclocking so would do the job perfectly until you maybe wanted to change it :D
