Caporegime
- 9 Nov 2009
- Planet Earth
Thank you i upgraded the PSU and downgraded the SSD since its only having windows on it. I already have windows 10. Thanks for the help guys
The Nano S is a mini-ITX case,so not sure a mATX motherboard would fit,so I assume they meant another Fractal case.
Plus seriously just avoid that H110 motherboard - its pointless. Its a crap chipset and the motherboard only has two RAM slots.
That B150 based one I suggested adds basically £4 to the total cost and it has two extra RAM slots.
If you try and upgrade the RAM on the H110 motherboard you will need to buy a 16GB set,instead of a cheaper 8GB set.
Edit!!
I have a mini-ITX system,and TBH the lack of RAM slots is a major limitation. I had 8GB originally and had to buy a 16GB set when I upgraded instead of a cheaper 8GB set.
OTH,at least with a mini-ITX system I have a more compact case which is the reason I got one,but mini-ITX systems are not cost effective IMHO OFC.
. I downgraded the SSD to a 120GB added the SeaSonic PSU that was given as an option also. I didnt change the case as i really like that one with the red led fan at the front that is why i added the 2 extra ones for the glow inside. I understand why you all said to change the motherboard but its just a starter build i have recently moved into a new home and had a baby so the price just fit my budget. Im sure i will be happy with it till the time comes when i can upgrade bits and pieces. Thank you for all the replies much appreciated
