Please help with 1st build
Thanks and hello again, Stulid.
I am reading the motherboard manual and having a nerve soothing beer and then I think I shall embark on this increasingly scary procedure.
Thanks for the advice. I expect I will be back shortly to ask some stupid questions.!!
It will say which ones to occupy first, a lot of boards wont work when the other pair are filled up first.
I think the motherboard also has a few little front panel connectors in the bags, that you put the wires into, then insert these colour coded into the motherboard, nice little feature.
hi
You are correct, I have found those connectors for the front panel wires. That is going to make life a lot easier.
I have now read everything I can and am getting going.
First mystery - The PSU is located on the bottom of the case. There is a grill on the bottom but it is quite shallow and looks like it wouldn't let a great deal of air through. I thought I might just put the PSU in with the fan facing up. Can anyone think of a problem with this?
The case manual says there are 2 types of PSU. "Independent cooling" which would be best pointing downwards and "Case Air Circulation" which cools better if the fan points inward.
The PSU box and instructions dont mention which type it is. Should I just put the fan face down and trust that grill thing or should I have it face up into the case?
Thanks
yes.
looks like?
Ok.
Now I have installed the HDD the DVD drive and the PSU in the case. The processor and the cooler and the REM are in the motherboard. I thinkn the cooler is on although it didnt take much pressing to fit. Now to lift it into the case. The fear builds....
