Please spec me a 5080
10 Feb 2011
Hi all
Max £3,200 once in a 6 year upgrade been waiting for 2 years for this. I want everything to be compatible as they can. 2 SSD and 64GB ram, Flight sims etc.
Thanks.
Not building it my self i will ask OCUK to do it like i did 6 years ago with this PC.
The demo one is much better value in my opinion, particularly if you make an offer. I think the DIY build I spec above would also be better value after OCUK add their build charge.
What about the fan on the pre built is all in one water cooler and looks like has 7 fans on case too. I want it quiet as possible too.
I'm not sure what the demo includes, since that case has no fans by default, but I'd imagine if they used it as a demo, it had at least enough.
A 360mm AIO is overkill for a 7800X3D/9800X3D, the freezer 36 or peerless assassin handles them fine.
The case in the DIY build (Lian Li 216) has a good bundled fan config.
One question. what you mean by demo lol.
16gb VRAM is an issue as well if you’re planning to keep the card 6 years.
The only reason i didnt upgrade this pc is the price vs performance. Coming from a 2080ti to a 5080 is a big jump along with newer other parts etc and a clean up to date pc with better fans. It might be different with a 5080 and jump to a 6090 this time. I dont just want to buy a new card for this PC. If i do no in me something else will break and fans on back case sounds wobbly after all these years too.
Back in voodoo graphic card day i would upgrade all time but today dont seem worth it.
Im just tempted to buy this
How come it costs a extra £80 to put a 9800X3D in yet in the shop it is only £30 more than the 7800X3D?
Just wish OCUK would say what make of card you get.
*Build* Gainward GeForce RTX 5080 Phantom 16GB GDDR7 Graphics Card.
Agree with Tetras, gives you around £650 for build cost and Windows.
How about changing the SSD to a WD Black SN770 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T3X0E)
And CPU to a
AMD Ryzen 9 7900X3D Twelve Core 5.60GHz
£3,314.99
They must have added the graphic card choice recently thats good. What the card like on noise.
I got a Philips 27" 1440p Evina monitor and a M32U 4k monitor
My PC now is
CPU 3700x
Mobo x570 a pro
16GB ram 6000mhz
Zotac Amp extreme 2080ti
1TB wd black sn580 nvme I think thats the make i know its WD any way but pretty sure its that.
As said bought 6 years ago from here at £2500. Been happy with it until last 2 years or so and been waiting for these 5080 to come out and think the 5090 is a bit way too much.
And CPU to a AMD Ryzen 9 7900X3D Twelve Core 5.60GHz
You're referring to the prebuilt Scimitar?
The 7900X3D doesn't make sense if you're only gaming because it is actually slower than the 7800X3D in most games.
The SN770 is fine.
