xsnv said:could someone pls help me out. I'ts a simple question. which is better for gaming and general everyday use?
Amd x2 4400 @ 2.8ghz = ram at 254mhz 3-4-4-8 1:1
or
Amd x2 4400 @ 2.8ghz = ram at 211mhz 2-2-2-5 on a divider
Cheers
xsnv said:I would if i could...Im asking so i know which ram to purchase (g.skill hz or zx)
Cheers
Richdog said:In that case the ZX without question, they OC well too.
El Jimben said:2GB ZX kit is like £190 nowI thought paying £150 odd was bad enough 2 months ago!
Hades said:I did some extensive testing of RAM speeds using my Ballistix and found that in Doom3 my framerate was slightly higher at around 250mhz compared to 200mhz with tighter timings. This is at odds with what most people say but it's what I found.
xsnv said:I'm a bit more confused now though. So running the ram much higher is better than tight timings on a divider?
Hades said:Unfortunately I wouldn't think RAM prices for DDR will drop very quickly. As more people move to DDR2 then the cost per unit for producing DDR increases. I'd also not recommend 1gb at this time. If you want to upgrade to 2gb in the future then it could be expensive: either adding a further 2x512mb (and therefore running at a much slower 2T timing) or selling the old memory and buying 2x1gb.
Right now there are bargains to be had second hand as people move to Core Duo ("Conroe"). Personally I'd recommend buying some good quality used 2gb (2x1gb).
