- 22 Feb 2014
Had a bathroom fitted that is now finished apart from the bath panel.
Plumber days he is aiming to get this week to fit it.
What he doesn't know yet, is that the bath sits 5mm lower at one end so the bath panel doesn't fit.
It's a curved bath and obviously a curved panel.
I have adjusted the leg on one corner which has levelled the bath on the front edge, but the back edge is tiled in so has nowhere to go and won't raise up any more.
If I force the panel under the bath it bows out and looks terrible.
The panel itself has a lip top and bottom,
what would you accept as a solution?
1. Rip out tiles, reset the bath and retile (he didn't tile it himself so will have to get the tiler back in)
2. Cut the panel and lose some strength.
3. Trim 5mm off the bottom of the bath lip to allow the panel to fit.
4.???
any advice would be appreciated at this point.
4.???
