Caporegime
Today...When is the next thread?
I will be getting my mechanic to have a look, but obviously it is Sunday tomorrow, so this is more of an "in the mean time, what can I try" thread.
My car is a 2002 VW Polo 9N 1.2 6V AWY with 138K on the clock.
I was driving home earlier today and the 'check engine' light came on.
There are no strange sounds coming from the engine, the engine idles smoothly, the engine pulls fine through all gears, there is no "lumpiness" and no misfires throughout the entire rev range. I have checked all fluids and all seem fine, I have checked all hoses and plugs as much as I could at the side of the road (just visual checks for obvious splits or loose hoses/disconnected plugs etc) and there don't appear to be any obvious issues.
I have tried various methods which are supposed to clear lights/errors or reset the ECU (I don't know how many [if any] of these are genuine methods but I tried these regardless):
- Pressing in trip button for 2 seconds and turning to the right
- Pressing in trip button for 2 seconds with key turned to lights position, and turning to the right
- Pressing in trip button, holding, turning ignition to lights position, holding, turning ignition off, removing keys, and releasing button
- Disconnecting negative terminal for 15 minutes and re-connecting, then starting engine
- Disconnecting negative terminal for 3 minutes, then re-connecting, then turning ignition to lights position, waiting 3 minutes, turning ignition off, removing key, putting key back in, then starting engine
Points to note:
- Engine had a full tank of petrol when this happened, it was cheap supermarket petrol though (Tesco 95) and I usually use Momentum/Ultimate/Super or sometimes Esso 95
- Radiator fan is faulty and non-working (blows fuses) but it has been like this for 2 weeks/500 miles, I have been careful with the engine, and never seen it go above 90 degrees. (replacement fan is in the post)
- The car was involved in an accident a few weeks ago, but it has been fine from after the repairs up until now (again, 2 weeks/500 miles) and it was fine before (never had the light come on)
The only engine component which needed replacing following this incident was the radiator.
If anyone could shed any light on the subject or give me things to try, it would be much appreciated!
I do not have access to any diagnostic equipment.
Finally, would you advise against driving the car while the check engine light is on persistently, even if there are no obvious issues?
Kind regards!
