Poor seagate 7200.10 in raid0 speeds
3 Oct 2003
Northampton,UK
Hi, i seem to have an issue with some new seagate 7200.10 (320gb) drives i have installed.
I have configured them in a striped raid0 array with 32k stripes using my nivida raid controller on my asus a8n deluxe board.
The raid drivers are slipstreamed into my XP install using nlite as i dont have a floppy drive.
Here is a screen from HD TACH showing their performance:
As you can see they are not reaching their full potential :(
They are not jumpered, iv'e tried new sata cables, tryed swapping sata ports and i have disabled read caching on both drives.
Cant think of what else to try :confused:
Normally poor performance on NVidia RAID stripes is down to the read caching being on but if you've disabled that then it's something else :confused:
Have you got the latest Forceware drivers for the disk controllers?
Iv'e done a full install of nvidia 6.86 nforce drivers and i said yes to the IDE SW driver as well.
Disabled write caching as well now and i get a higher burst:
but read speed is still very poor
Are you running a 680i board?
If so it's a common problem with all reference boards (which excludes Asus & Abit)
I've switched back to non-raided drives for the time being until a new bios is release which resolves the problem
Still having problems with the raid speed, so i disabled raid and installed windows to run HD tach on each drive.
First drive that windows was running from was getting 41mb/sec average read
The other one gets 65Mb/sec.
Does it sound normal? i was not running any apps or anything while i was doing the tests.
Just swapped the drives around so that the slow one was not the OS drive anymore. Still got the same result..
Here is the slower one:
And the other:
Guess this explains why my raid was so slow, the system kept waiting for the other drive to catch up.
