portable external with reliable usb power?
19 Oct 2002
hi guys,
could anyone recommend a decent portable external (2.5") drive that works reliably through the usb power source? i was looking a WD Passports but apparently the drive requires more juice than the average usb port supplies causing failures...
i really like the simplicity of not needing a power cable so it'd be great if you could recommend :)
my father in law has a sweet philips portable drive (the usb cable wraps around the ridge and is very neat and compact, but that seldom works without the AC power :(
Just grab a Seagate 7.2k 2.5" and then get a cheap case from ebay (the sony vaio one works well) Most decent 2.5" (vaio included) come with double USB connectors so that 2x 500mA can be supplied if needed.
I've got a WD Passport, never had any problems with it, power wise. As long as it's connected to a powered port, it seems quite happy.
