Firestar_3x said:Cheers for the info, should some SSR1 do the job? Don't want to go to abrasive since my scratches swirls can only be seen at the right angle.
Just about to order a 7424 with some Sonos DAS pads, apart from a 240 / 110 voltage converter anything else i need?
Got some Meguiars stage 1 to get the paint nice and smooth can this be put on with the PC?
Then get rid of the swirls using the SSR / perhaps polish using my Autoglym super resin afterwards since its a very fine cut then wax using my NXT Tech, worth sealing using autoglym extra gloss protection?
How deep are the swirls? SSR1 is very mild and might not be strong enough to get them out. Try it though and if you find it's not harsh enough just get some SSR2 and use that first, follow that up with the SSR1/Autoglym for a perfect finish. Finally just give it a coat of wax and you should be done.
The Megs can be used on the PC but if you're using the SSR you probably don't need it.
