wohoo said:Merlin, when you pic the PC up, and have 'practised' on your own car, come round and do mine will ya mate![]()
housemaster said:So let me clear, the group advice is I such desist in the use of my Black and Decker circular sander then?![]()
I prefer to blame the wife!merlin said:Na it'll be fine.
For really deep scratches I prefer my Electric Planer.
[TW]Fox said:In my complete noobish way I was wondering how a multi hundred quid 'Porter Cable' differs from a Black and Decker, providing you use the correct pads with both..
Actually if I remove the humour element I have a Bosch circular device and it did come with a polish pad and a duster pad and it is variable speed so I see no reason why with a little care it would not suffice. Mind you, don't really want to try it out on mine...[TW]Fox said:In my complete noobish way I was wondering how a multi hundred quid 'Porter Cable' differs from a Black and Decker, providing you use the correct pads with both..
merlin said:Man you're brave letting a 100% noob loose on your spanking new car, do you like the matt finish?![]()
I was going to get a scrap panel to practice but tbh I can't be arsed.
Going to print that guide off and follow that.
It's really quite light swirl marks only visible under strong electric light but I know they are there and I want them gone.
Does anyone know how much polish I'll need in ml?
merlin said:One will cause more swirl marks than when you started, and the other won't.
housemaster said:Actually if I remove the humour element I have a Bosch circular device and it did come with a polish pad and a duster pad and it is variable speed so I see no reason why with a little care it would not suffice. Mind you, don't really want to try it out on mine...
[TW]Fox said:With the correct pads and speed setting, whats the difference![]()
.Andy said:Doesn't sound like too bad swirling then, you'll probably get away with just using Menzerna Final Finish polish, and 250ml (the smallest you can buy IIRC) would easily do you and probably another car. Too much polish and its just going to take ages to break down, when loading the PC I draw a cross on the pad with the polish then a tiny drop in each quadrant.
[TW]Fox said:I dunno, whats the difference anyway?![]()
Kingy said:Are Maxtool worth dealing with?
They are advertising the 7424 at just under £85.
