Possible dead dying drive...
31 Oct 2005
South-West
Hi there,
Got 3 250GB HDD's. Two are Maxtors (bought ages ago while I was dumb) and a WD.
I have Vista on one Maxtor nearly all my music, videos etc on the WD and the other Maxtor I just use for other files and family space.
I was getting a lot of slowdown in Vista x64 recently and lost a lot of space (25+GB) I thought the drive was dying. Ran HD Tach and it came back ~58mb/s so was quite pleased (drive isn't that new) Tried other drives and the other maxtor came back ~58mb/s as well, the WD came back at ~54mb/s and was making a lot more noise than the others though:(
I then check fragmentation using the CLI and found my drive was qutie fragmented. Went on the hunt for a decent defrager and got O&O Defrag 10.
Now that all went fine, it ran fine on my two Maxtors. When I tried doing the WD I scaned for errors first, started doing it then CLICK, it stopped scanning the WD. I told it to defrag and it start therer saying SPACE [wait]. The other drives were fine though.
I reset thinking not a lot of it at the time. After a reset I ran the defrag program again on all drives at the same time and thought I could hear a clicking noise quite frequently. I stopped all HDD defraging and the clicking stopped. One by one I started them and found it to be the WD.
Does this mean it's on the way out? I mean the WD is the oldest (about 2-3 yrs) but will it be on it's way out yet?
I ran the WD diagnogstics on the drive and the quick passed but made a baaadddd noise while doing it and the long is 10 mins through with 55 mins left. If this passes would people still recomend back-ing up? I would back-up now but I don't have any monies for a bigger HDD:(
If people think that it's on it's way out could I return this one or would it have to be not working for WD to give me a replacement?
I was thinking about getting a 500GB HDD for xmas and using that for the WD and the spare Maxtors job and putting both Maxtors in RAID 0 but I have now heard that it won't give me a performance increase:(
Cheers in advance, Doug.
if you suspect that your hdd is dying or even if it is not, your common sense should tell you to back up waht you can't afford to loose (if money is a problem) or what you don't want to loose (if money isnt that much of a problem)
