Possible Radeon 390X / 390 and 380X Spec / Benchmark (do not hotlink images!!!!!!)
Status
Not open for further replies.
Is this the longest life re-brand ever? Re-branding and re-releasing a card that came out 1 year and 9 months ago!?
LMAO@'Enhanced Hawaii'
:D
Lemme just share the naming fast
You think it's different internals and not just a new shroud? You do remember we're talking about AMD right? :P
I think AMD either upgraded the ref cooler, or just use the old design on lower end cards with low TDP, and put something other onthe higher end ones.
So its around a third faster in compute overall than an R9 290X,but on unoptimised pre-release drivers too.
You might be right! :(
Edit!!
So it appears,that Fiji jas 4096 shaders,which is a 45% increase over Hawaii.
Unless AMD has cocked up somewhere this should end around Titan X level performance,but it might be even faster:
http://tpucdn.com/reviews/NVIDIA/GeForce_GTX_980_Ti/images/perfrel_3840.gif
http://tpucdn.com/reviews/NVIDIA/GeForce_GTX_980_Ti/images/perfrel_2560.gif
Based on the TX vs 290X numbers, the two first graphs seems to be the one to look..as no gaming bench showed the TX being 2x faster than a 290X like on the last two
That list matched Sapphire retail products list:
•Sapphire Radeon R9 390X TRI-X OC 8GB GDDR5 (11241-00-20G)
•Sapphire Radeon R9 390 NITRO (TRI-X OC) 8GB GDDR5 (11244-00-20G)
•Sapphire Radeon R9 380 NITRO (DUAL-X OC) 4GB GDDR5 (11242-07-20G)
•Sapphire Radeon R9 380 ITX 2GB GDDR5 (11242-02-20G)
•Sapphire Radeon R7 370 NITRO (DUAL-X OC) 4GB GDDR5 (11240-04-20G)
•Sapphire Radeon R7 370 (DUAL-X OC) 2GB GDDR5 (11240-06-20G)
•Sapphire Radeon R7 360 2GB GDDR5 (11243-00-20G)
http://wccftech.com/amd-sapphire-radeon-r9-300-series-listed/#ixzz3cYIWvoAs
So Fudzilla told the truth that Fiji XT is the water cooled one and Fiji Nano was not listed on AMD slide, here are only 2 favours XT and Pro.
Status
