POST issue
26 Apr 2004
Kent/London
Last week the Tagan PSU blew on my rig. Today I received a Corsiar HX850W from OCuK and I have spent the last few hours fitting it.
The issue is now that all the fans, cpu and motherboard begin to boot but the graphics card does not boot, the fan does not move. Its in the 1st PCI-E slot same is it always has been before the psu blew. I have used both the hard wired PCi-E cables on the PSU and modular ones and nothing. I happen to have another GTX 260 so tried that and same thing, even tried in slot 2 in sli mode but neither fans spin. It seems no power is getting to the cards.
Is the motherboard faulty now due to the PSU blowing?
Thanks.
well the PSU fires up the cpu, case fans, hard disks and DVD. It just seems to be the PCI-E power thats not working. The Corsair comes with 2 hard wired PCI-E cables and 4 modular. Ive tried both types buy nothing.
its an odd one that, do you have a spare psu you could try?
Afraid not, the last psu blew up so only have the Corsair. Would the fan on the GPU spin if its just connected to the power or would it need to be in the slot?
not sure on your gfx card, but i know my 9800GTX+ if i forget to plug 1 or both of the powers into it, a red light comes on, and a green one if its all good, worth a look maybe?
I must be missing something here!!!
I have used all 6 PCI-E sockets on the psu, interchanged the cables etc and nothing. I will get a multimeter from work tomorrow and see what the Corsair is outputting.
sounds like a dodgey psu, i would imagine the fans would spin even if the mobo was dead, but unsure.
like i said, are there supposed to be any lights on the card to indicate if there is the correct power?
There is no LED that I can see anywhere on either of the gtx260 cards.
Well I only had one originally and just got the 2nd one yesterday from a mate. I saw it working and was there when he pulled it out the test rig. So when the pdu blew I just had the BFG one installed.
