Post Your Cooling Screenshots Here!
AMD Opteron 144 UP @2.7GHz, 1.475V according to BIOS, 1.5V according to Speedfan.
I'm none too happy about the load temps, but the HSF was only a temp mesaure anyhow. I'd love to know how the other guy with a 144 got such low temps with it as its a pile of rubbish =\
What heatsink and fan do you have? Your case temperature is none to great either which wont help your cpu temp.
I'm none too happy
Hi,
Please ammend your post to include what HSF you have and mobo etc (like what everyone else has done...nearly! ;) )
Big.Wayne said:
Hi,
The graphs it makes tell you what motherboard it is anyhow? Onto his fan, I'm guessing it may well be the same as mine cus I think I am the only other 144 owner that has posted?
marc2003 said:
i must be a bit fick. i can't seem to get any graphs out of it. checked the folder in \program files but it's empty.... :p
so can anybody help with this? i assume you lot are just running the 30minute test and the graphs magically appear..... :p
C:\Program Files\OCCT\Graphs
Not in there? go to the options and make sure it makes them? I don't think you can turn it off though!
Same spec as above but running at 2250mhz (250fsb) default core voltage (1.4) on a KN8 Ultra
Interesting how the load temperature doesn't change much from the other, any ideas as to why? Either the heatsink is good thermally or bad :confused:
Edited : Abit KN8 Ultra, Opty 144 at stock volts, 250fsb with Vapochill micro Extreme.
opteron 165 @ 2.7 CCBIE 0550VPMW
corsair 2 gig cas 2 v1.2 @ 1T 2.5 3 3 11 (ram limited)
Custom "ghetto" watercooling consisting of a maze 3 block
tygon 360 silicon 1/2 inch
ehiem1250
Vespa radiator
silent papst 120 ml on zalaman fanmate
Asrock dual sata 939 mainboard
i could go higher it boots/games, no prime, at 3 gig could stable 2.85 but cba with the extra cooling as can go 55-65 degrees :eek:
EDIT edited to show correct sensors
case nb & sb are passive cooled on asrock 939 dual sata
Aye, arent your temperatures the wrong way around? I cant see how the case can be that much hotter and yet the cpu sits at 33. I'd say your case temp is actually your cpu?
Thats the northbridge though not the actual case ambient temp and that board is passively cooled so it might be right.
nar. its clearly cpu + system temp mixed up...
what cooler allows the cpu temp to remain constant from idle to load ?
None afaik... and look at the general trend of mine and everyone elses, the temp rises after the idle time the program runs first of all.
