Post Your Cooling Screenshots Here!
ah crap yea, well aint that a little hot for stock and max speed from my cooler? Only had the CPU for like a day or two if that makes any difference.
Opteron 165 @ 2.6 (1.525 V)
MSI K8N Neo2 Platinum nForce3 Ultra
Swiftech H20-220 Apex "Ultra" watercooling
4 120mm & 1 80mm case fans (for the 12 HDDs ;))
Athlon 64 X2 4400 @ 2.8ghz 1.55v
Dfi Sli-dr
X1800Xt
cpu/chipset/x1800 watercooled. 120.3, nexxos cpu block, silverprop sl gfx block
All done in quite a warm room :)
hello
i just ran that test...but 50% thru PWMIC was 100c...any know how high that can go?
think i need few more fans :)
  • Opteron 144 @ 2.9Ghz (1.55v in BIOS and measured with Multimeter). IHS removed (dropped temps 5 - 7'C)
  • DFI NF4 Ultra D
  • Alphacool NexXxos Waterblock
  • Dual AQX 50Z pumps (in series)
Check out the stable 0% Ripple Vcore! :D /pats OCZ Powerstream 520
Note that the DFI NF4 under-reports Vcore by some way... :eek:
westie17 said:
Are my temps a bit much? Other people have overclocked chips and im getting higher temps than them @ stock.
All these temp. comparisons are pointless because each brand of motherboard gives different temperatures! Hell, each motherboard gives different temperatures!
This is because those of us with widescreens can have two sets of results side by side to compare. .
Yes, but his case temperatures are quite abit higher than yours.
4 reviews I have read state that under the same conditions the Scythe Ninja beats the SI-20 and XP-120.
I'll wait untill I have my panaflos delivered with my Scythe Ninja and I'll do these tests :)
Steven said:
Northwood 3.0 @ 3.6
P4C800-E Deluxe
Zalman CNPS7700-CU
Lian-Li PC-61
Look at that vcore drop! :eek:
hahah thats about nornal for those boards...
i cannot run it because it counts down to zero then just continues for ever saying monitoring please wait. :mad:
Amd 64 3500+ @ Stock Speeds
Asus A8V Deluxe
Akasa Evo 33 @ Lowest fan speeds.
4 Akasa Amber fans in the case, every single fan in the case was at the lowest speeds.
All Housed inside a Coolermaster Wavemaster
