Post Your Foobar Setup No Larger Than 800x600
How do you go about moving the sidebars and things around, changing the layout? and how do you make it look all pretty?
Playlist area is a slightly modified version of a freely available Columns-UI configuration. Green ticks are for Replaygain, and red circles are relative playcount values.
Sidebar uses Album Art Panel and Tabbed Panel Stack with the Track Info Panel, Album List Panel and History. Should be all available at the HydrogenAudio forums.
Check out the plisk config :). Switch the color-scheme setting in the script to the third one.
Code:
// COLORS
// available color_themes
// 1 - original dark theme
// 2 - b0se Blue (from Neksus)
// 3 - darkblue (from bonj)
$puts(color_theme,3)
Here's mine:
If you want the .fcs just ask.
