- 7 Mar 2005
- LU7
Computer ----> NIC -----> Cable -----> CAT 5 cable -----> Hole in the wall -----> University of Salford's rubbish network.Computer ----> Router ----> Internet thingy
aren't all these super routers/switches a bit overkill?
Why did you have to post this DRZ... so much effortlol
Anyway:[snip]
You binned a Sun Sparc!!! Sacrilege man.
Other than that what else would you need?
Simon
How about some more subnets? Perhaps some VOIP? VPN or two? OSPF?![]()
Guess i just mess around with the config too much for it to be remote, and talking of load balancing I really want an ISP that gives me BGP
Also, on the subject of Clustering, I am planning on setting up a solaris cluster suite 3.2 cluster using a ZFS Fileserver and iSCSI (now that iSCSI supports Scsi3 persistent reservations) instead of expensive FC connectors, should work well, and be kinda cool![]()
Well BGP isn't a problem, convincing an ISP to give you BGP over a home connection will be though...would also mean your own AS and the like though.
I did have a thought about setting up BGP and getting a full internet routing table at home (it was for a project) but I gave up on the grounds that any router meaty enough to run a full routing table would be LOUD. (that I could just do it in the lab)
.. That was the problem I meant, getting a home ISP to give me BGP..
Ahh if only. Any recommendation on the cheapest business provider that would support this? (Just wondering if you know, don't go to any trouble looking into it ;P)
