Post your Idle temps
Room temp 22c
460 Hawk GPU 1: 47c (x16 slot)
460 Talon GPU 2: 45c (x8 slot)
Hawk clocked at Talon stock speed.
Load Temps Room temp 24c
Heaven bench 2 runs
GPU1: 70c
GPU2: 68c
Far too hot for them both in x16 slot as there's hardly any gap between the two, very minimal fps difference in benchmarks.
Room Temp 22c
Idle:
GTX 480 (1)- 32c
GTX 480 (1)- 33c
Full Load:
GTX 480 (1)- 48-52c
GTX 480 (1)- 48-52c
Gotta love watercooling - 2 x 360 Rads with 3 fans on each on very low speed. (Does CPU as well)
^^ Chiily room !
Just realised all my case fans are on almost stop - turned them up slightly and added an MSIAB fan profile now 35 and 43 :D
Asus 5850 dual monitor on air cooling
Underload temps based on Battlefield 2 on high settings with fan set to 35%-35c
45%-45c etc
Clock 725/1000
Idle 35c Underload 53c Max
825/1100
Idle 35-38c Underload 54c Max
950/1100
Idle 36-39 Underload 55c Max
5870 with ek 5870 nickel acetal custom water. Load temp after 20mins gaming.
Ambient 20
Idle -21
load - 28.5
idle
load
Is that water cooled Gareth? they are some crazy low temps.
GTX 480 850 core
Idle 42c
Load 82c
Edit, can see you have fan speed monitored so I guess it's air cooled, what games are you playing that gives them temps.
GTX 480 850 core
Idle 42c
Load 82c
it's air cooled.
i ran Heaven Benchmark v2.1 for 5-8mins
my room temp is 19c.
most games i only see the temp go to 49c with fan at 48%
